How little is "a little"? Generally Ultimakers are pretty damn accurate mechanically when set up correctly. However, shrinkage of the parts can cause issues if you need super accurate parts. Different parts will shrink differently depending on their shape, what plastic is used, temperature, infill etc etc so if you need super precise parts you'll need to tweak the parts in CAD to get there (holes for example are notorious for becoming smaller than designed).
This isn't unique to this type of printer, it happens in the big boy world of injection molding as well. I visited a place like that about a year ago and the boss showed me a part where they had to set the bend of the part slightly too big so that it would become correct as the part cooled down after being ejected. Crazy stuff
I will have to run another test to get some better numbers then, because I had some temperature and under extrusion issues at the bottom of the print. But ignoring that I assume its not possible to change anything to improve it after I find my temperature of the filament
IRobertI 516
