kmanstudios 1,120
Paints usually belong in an eco-system: Acrylics with acrylics and solvent based with solvent based. Also, making sure what will bind, will bind well. Also there are brand based ecosystems.
Also, usually you can paint acrylics on a good primer base and then solvent based on top of that will usually work. This allow me to paint with an acrylic primer and then paint with any solvent based paint.
In this print I used only the paints with the same base properties (as well as a brand based eco-system). These paints are part of the Dupli-Color anodized paint series. They provide a metallic look. They are part of the metal cast paint line.
The far right bottom pointy things are the base coat that they provide with the system. It works best with their paints. Again, self enclosed ecosystem. I did violate one of the rules here though. The abalone hair is acrylic slowly built up over the solvent based paint. A lot of patience can go a long way here. But it is the only space that I did this. I guess I will see if it flakes off in few years. But experience says it will not. I cannot explain why, But I have found a few exceptions over the years and when properly applied. With the hair, I had to lay a lot of layers to get it to stick properly. Once I had the paint ready to stick, I could layer transparent colours until it build up properly.
The only other exception of going out of a brand's ecosystem (But still solvent based rattle can) was the Venus character herself. I printed her and the base separately. First to make sure that the base and figure could be treated differently should I run into printer issues. With a 23.5 day print on the base, and the figure being the possibly most problematic (And, she was having to print her twice) I wanted to avoid having to print the whole thing again.. I did use a basic spray gold misted over the Dupli-Color base coat. I misted from top to bottom so that by the time the knees get painted, it fads out to the base coat. I misted only enough to make for a warmer colour and not gold itself. I use misting a lot. Sometimes, it works and well, sometimes it can get out of hand and resulting in painting colours in and out until you get the colours you wanted.
I did this to bring out the warm tones on the figure to 'bounce' out from all the cool colour range of the blues and bluish silvers.
As a final touch, I used the last of the Holographic paint I had on hand. Not much, but barely enough. These paints are part of the Spaz Stix line of paints. These paints are solvent based and not the same as having a holographic powder. As an overcoat, it provided the colour reflections in this pic.
All those nice colours of blues and purples are the result of the holographic paint. As the object turns, the colours play over the surface. And, they allow the base paint to be seen.
- 2
kmanstudios 1,120
OK, so I tried something different: Ornaments.
My first ones were primed and painted with Krylon's original Chrome.
The spiral ornament was left alone, but I shot some anodized paint over it.....meh.....
So, I started to put washes of Pthalo Blue and Unicorn Milk. I built that up until it was a very deep, rich blue with pearlessence. The silvering parts were done with Semple's Holographic powder (Technicolor).
But, shooting clear over the ball softened the out layers of paint and, well, let us just say that you should not drop them or it will tear until it is solidly dried and bind again to the silvering paint layer:
Then I painted the spiral. This one worked much better and only had the silvering layer first. Again, Pthalo Blue mixed with the Unicorn Mil in thin washed layers until I got the brilliant metallic blue I wanted. Then I used the Mirror Chrome from Semple's line of paints mentioned above.
Even though it worked, I switched tact on this to just a black primer over painted with gold pray. That did not work. It was just too dull. So, I went back to the black and used mica powders and that really worked much better. It was hard to get a good red out of it. But, also being so reflective it picked up the gold and further diluted the color red saturation. The powders were mixed with Unicorn Milk as the finding medium.
Then I put that gold mixture over this ball completely and then washed some Pthalo Blue and Unicorn Milk until I got the green I wanted. By using the Gold all over the ball and washing over the blue, it was going to carry a 'matching' component since it is partly the same color after all.
