GregValiant 1,330
It's good to have that explanation @kmanstudios. From the engineering side:
This is a horizontal pocket for a hex nut. "Make Overhangs Printable" is turned off.
This is the same pocket with "Make Overhangs Printable" turned on:
It does indeed make the overhang printable without support. On the other hand, the nut won't fit in the pocket and the screw will no longer fit through the hole. I don't see a bug here since it definitely made the overhang printable. As @nallath notes (and @gr5 has also) it does create a lot of confusion. There was so much confusion that I had suggested the tooltip be changed to "Do Not Touch" but after the explanation I'll go with "Do Not Touch Unless You Know What You're Doing".
1
nallath 1,124
Poorly 😉 (I'm still convinced that the function shouldn't be in Cura, and it causes a lot of bugreports from people that enable it without knowing what it does). I obviously don't know what you are using it for, but is this really what you need?
Cura goes into 2D as fast as possible by slicing. From that point on it pretty much does everything on 2d polygons. So almost all operations that we do are subtracting polygons from other polygons and inset & offset them.
kmanstudios 1,120
I enjoy the feature. Sometimes, when I am printing without supports (designed that way) there may be times that I have inadvertently put an angle here or there that would create an issue when printing. The 'make overhang printable' lets me turn that on without ruining the whole print as well as means I do not have to go back into sculpting the piece. I would say that it has to do more with artistic prints than engineering though.
Shape before slicing. You can see the hollows in the scooped areas.
Sliced without overhang printable. Slice follows scoops as modeled.
Overhang Printable on. You can see where it filled in the scoops to prevent printing in air. It did this without destroying the model.
For me, it is a way to compensate for some really strange model properties when I do strange modeling or severe undercuts. I can see where this would be an issue with engineering and would no9t make sense, but for artistic things, it has a use. Came in very handy with the 'weird critters' I was modeling.
But, there do not seem to be many artistic type of modeling as compared to engineering type stuff. If it were to be deleted, I would weep a bit (Seriously, there could be actual tears 🤪 )...but it would not be the end of the world.
Ummmm, is that not the case for any person just using things without understanding the feature?
Darned edit feature will not let me remover this final image. I go in, I hit delete and then save and it is right back where it is not supposed to be.
![RedAreas.jpg](//content.invisioncic.com/ultimake/monthly_2021_04/RedAreas.thumb.jpg.cc814cf0797033252c55a5286bd464c3.jpg)
Edited by kmanstudiosLink to post
