Now I just gotta find out how to mark this post as solved 😂
7 hours ago, zeal7726 said:Now I just gotta find out how to mark this post as solved 😂
Maybe change the title, and add " - solved" to it? Should be possible, I think.
1
@geert_2 - anyone (well at least the topic creator) can now mark a topic as solved by following these instructions:
1
Thanks! I think it might not have been possible before, because I am a new member and had no rights, but now I could updateit 😉
You didn't do the whole "solved" process. Try the instructions again. When you do it right there will be a large SOLVED word in a dark/obvious green ellipse before and on the same line as the topic title.
All right. I'll do it. 😞
gr5 1,968
gcode looks fine. I looked for bad feedrates (which can print so slow you thing the printer is stopped) or unusual M codes (like M1 which pauses the printer).
I would do a diff of the file on the SD card versus the "same" file on the hard drive to make sure it is not corrupted on the SD card. That's all I can think of.
zeal7726 0
Thanks for the idea! The File I uploaded was already from the SD-Card, so it at least seems like it was fine. I found the Problem: I was using an microSD-Card with adapter, and somehow this caused the problem (even if I don't know why exactly..).
