14 hours ago, sj3fk3 said:
Jonas this bug will be fixed in 6.4.1, do you want your name to be mentioned in the release notes? 😉
Yes why not 😄
1
- 2 weeks later...
Hi, not sure if this was introduced with this release, but I noticed an annoying bug:
When loading a new material, at the end you need to confirm material extrusion. Previously, if you didn't confirm extrusion, the printer would auto-confirm after a minute or so and stop extruding.
However, last week I forgot to confirm and ended up wasting a ton of material, today it almost happened again 😅
It would be nice if you could re-introduce/fix that feature!
I do understand that auto-confirmation might not be super-reliable either (what if something went wrong and no material extruded?), but you could always show a small dialog after extrusion was auto-confirmed to let the user know they should make sure everything is loaded correctly before printing :)
Or have the extrusion pause after a minute with a continue button to make sure the user hasn't left the room. Or cooling a bit and/or slowing extrusion to 1/10th speed (if you are worried about over cooking the filament).
Dim3nsioneer 557
Afaik there is still a timeout after five minutes or so. How large is the amount of filament during that time? It can't be more than 10cm of filament wich is less than one permille of a whole 750g spool.
I understand that there are more expensive filaments where one does not want to lose more than necessary. But that would just be a good reason to stay with the printer during priming and confirm the extrusion at the right time, wouldn't it? Please don't forget that it is important to see that the material extrudes normally for getting a good print.
On 6/10/2021 at 3:24 PM, Chaphasilor said:Hi, not sure if this was introduced with this release, but I noticed an annoying bug:
I do understand that auto-confirmation might not be super-reliable either (what if something went wrong and no material extruded?), but you could always show a small dialog after extrusion was auto-confirmed to let the user know they should make sure everything is loaded correctly before printing 🙂
We are going to look into it!
1
Another not so nice thing that happend top me just jet: (UMS5 Bundle)
Printed something with PLA black Nozzle 0,4.
Removed the print. (Filament stays in tube but 3cm away from Print Core)
I had to print something with the same filament but another nozzle...So:
-Click change print core
-Changed the print core to 0.25
-Started print
but...Last time the Print Core 0.25mm was used with white filament...and in this constellationthe printer is not priming/cleaning the nozzle
Since upgrading, have noticed that the display will not go into sleep mode. Stays on all the time when the printer is not in use?
- SandervG unpinned this topic
sj3fk3 22
Yes, we are working on that.. Cura can be stubborn now and then 😉
