Hi @elnadav12,
Been away for some times..
Just wonder if your nozzle is just too big or maybe to much worn?
As you've changed parts in order to any remove mechanical play(?). This lines might move slightly in and out due to worn out -or too big nozzle size. Have a look at this -I'll assuming you're using a standard size 0.4 mm.
However, your nozzle tip looks "some" worn to me (see last picture).
Good luck.
Thanks
Torgeir
elnadav12 0
No one here had anything similar?
