@Carbon, i did open the link, but how to get that things into the cura software on my computer.
You can also use any other color in Cura it doesn't matter which color you really have. There will be just a prompt that you have loaded the "wrong" spool which you can override.
But try the package mentioned above. You can install it directly from Cura when you click on the marketplace on the top right.
@Smithy thank you very much, it did work
Carbon 29
Paramesh, try adding this to Cura: https://marketplace.ultimaker.com/app/cura/materials/UltimakerPackages/UltimakerTPLA
