I wasn't using grouping, but it seemed logical that those features were removed with the removal of grouping. They were definitely still there in 7.x firmware versions - like I said, I was literally using them yesterday and watched them disappear after the 8.1 firmware was installed. Unless my machine somehow managed to retain features from old firmware despite being upgraded (seems implausible to me), you are simply incorrect about when they were removed. Whatever your internal notes say, I literally just watched this happen. My management console had four tabs yesterday morning; after the firmware upgrade and reloading the management console, there are only two tabs. One of those tabs was related to groups btw, further supporting the fact that those features were removed with this upgrade.
As for the API, you are also incorrect that most of those functions are there. In actuality, none of those functions are fully available through the API. There is job history in the API and it does have a bit more information than is available in the management console, but that is the only one of the four I listed that could be considered to be there in any capacity. The history available through the API is still not equivalent to what used to be in the management console and is far more difficult to use, but at least it is there. It is the only one though. There is no replacement for the material usage reports, job completion rate reports, or other reports that used to be on that page. There is no information about maintenance status available through the API. And I sure don't see a way to send a print job from the history list back into the print queue again.
These were all really useful (and used!) features that should not have been removed. My machine is in daily use and I depended on all those features. I mean no disrespect, but if you'd spent any significant time using the machine in a production environment, you would know how important those features were and you would definitely know when they were removed.
3
rachael7 59
Nope, I was on the latest channel, running whatever the last version was. 7.1.3, I think? I'm absolutely certain that was the case because I've been trying to diagnose some mysterious problems with Fbrc8, and at their instruction, I downgraded the firmware, tested some, and then ended up upgrading it back to current again. I know those features were there before I ran the 8.1.0 upgrade, because I watched them disappear from my Management Console when the page refreshed. Were they not supposed to be there? Either way, if they were removed before now, I'd still like to understand why - they were all very useful features! Thanks for your time.
Dustin 30
I just double checked the internal notes on the firmware 8.1.0 and 8.0 (8.0 is S7 only)
The only noted change was that "grouping" was removed in 8.1.0 which was already no longer support for quite some time now..
The management console changes were removed technically 7.0.2 .. The functionality was moved to our Digital Factory cloud platform. Most of the functions are still there but you need to use the api to access the information.
