For PLA I use 50°C on glass covered with a dried solution of water and PVA (wood glue). Works very good most of the times.
For your setting I don´t know the optimum teperature, but if it is too hot your first layer does not look that good. And waiting half an hour until your HB has reached the temperature is way to long. You can speed that up with a heat gun.
For finding the optimum temperature I would start with a temperature which works well for you, print a small object, lower the temperature 5 degrees, print again and so on. Until you found the temperature at which the object does not stick well anymore. Increase the temperature 5 or maximum 10°C and you have your optimum temperature.
nick-foley 5
PLA I use 65deg and blue painters tape. Sticks great, rarely need to use a brim.
ABS I tried 110 and blue painters tape, seemed to work ok, but only printed a few times.
