David Braam programmer from Ultimaker 3D Printers released secret snap shot of upcoming Cura at Erfurt 3D Messe Germany !
ian
Posted · David Braam programmer from Ultimaker 3D Printers released secret snap shot of upcoming Cura at Erfurt 3D Messe Germany !
    Guess that this is the famous GUI that Daid is working on at the moment.
    No pink unicorn shame :(
    Actually, the above is a photoshopped mockup.
    The actual implementation looks like this right now:
    I hope that fixes your disappointment :-)
    Brilliant !! :-)
    I love the new Unicorn feature in Cura !!! LOL
    Ian :-)
    Ooooo. A unicorn and a black magic feature... nice!
    Who volunteers to create a 3D model of the pink unicorn?
    @Daid, Cura is the BEST!
    I am pretty sure that the pink unicorn is allready the standard model when you load cura for the first time! Or you can choose between the robot and the unicorn... right Daid? :cool:
    whoa the unicorn really take it to the next level :eek:
    We need some of braddocks skills here... defenetly
    Damn, Daid, is this a revenge? did Gru destroyed your first fluffy unicorn :-)
    Sorry... Cant withstand.. :-)
    Design looks great!!!!
    I hope the surface problem in cura 14.03 is solved :???:
    Can't wait to try it out!
    Daid , i love this new look......Great, thanks!!
    Hoping to put out an alpha in about 2 weeks. That version will be filled with bugs ;-)
    Can you do a special one just for me, with no bugs please :p
    Then you better use the screenshot and your imagination.
    It's not a bug it's a feature :mrgreen:
    Just love the "plate" at the rear! How many times has my print started in the bottom left when I thought I had placed it in the top right
    That's already in the current version, if you select an Ultimaker or Ultimaker2 as printer.
    awesome
    We have installed with Cura-15.04.3.
    While trying CuraEngine -s "C:\Path\to\fileName.stl" -o "C:\path\to\fileName.gcoce" we are getting the gcode file but the contents are not coming as expected.
    We are getting the message as below:
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU Affero General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU Affero General Public License for more details.
    You should have received a copy of the GNU Affero General Public License
    along with this program. If not, see .
    Default config 'default.cfg' not used
    M107
    G1 F2700 E-4.50000
    G0 F9000 X0.00 Y0.00 Z5.00
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the
    nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of
    the way
    M84 ;steppers off
    G90 ;absolute positioning
    Kindly let us know the exact command to generate the proper file.
    Please let me know how can I get a correct gcode file
    Thanks & Regards,
    Debakanta
    Could you please stop re-posting the same question over and over again. It's getting a bit annoying.
    Hi Nallath,
    Sorry to trouble you. But I need your help.
    Thanks & Regards,
    Debakanta
        • 21 replies
