ah... I hesitate to use a metal tool, but I'm at that point now... Freezing did not help.. Yes it's likely that the glue is an issue here.
I froze it at 0 degrees F for about an hour... and still thermal expansion rates are not helping me... maybe the thaw cycle will break it free...
The funny thing is... I think if I wanted to glue a part with glue stick to a piece of glass, I'd have trouble having it hold...
I am definitely up for forgoing glue on PLA for some test runs... but i'm kind of blocked here, having only one plate to work with.
valcrow 145
I don't use Glue for PLA now, I started using it because instructions told me to.. but after a few times I tried it without and it works amazingly well at 60 degrees and you get a glassy smooth bottom.
If it's really stuck I usually try tapping it near the top of the print with something softish. (like the rubberized handle of a screwdriver) sometimes that pops it off.
If it's really stuck I use a pallete knife and poke at the corners which usually lift a tiny bit and it pops right off.
