bob-hepple 59
iRobert
thank you for taking the time to input your thoughts I will try your suggestion and modify the drawing I found this to be a positive input. .
Do you think I should leave the bed heated or not I have tried both but with no better results. Just some say turn bed off and print on tape, I know its a bit naff but as an experiment I printed on heated bed 60deg and then covered the bed where the over hang was to reduce the uplift of heat and with an extra fan on it.
Thanks
Bob
IRobertI 497
I don't have any direct experience with those types of printers so I'll just comment on your object. It looks like you have a simple overhang issue there. You've used a fillet for the bottom edge which produces an overhang that is difficult to print. Look at the picture here to see what I mean and a possible way to help get around it:
http://support.3dverkstan.se/article/30-getting-better-prints#chamfers
