DidierKlein 730
I tried printing ABS in a room that is not heated (must be around 10°c) it warps like hell, if the room where you print is not heated it will be harder indeed especially with ABS. A heated chamber will probably help a lot, do you know what's the ambient temp inside the box?
IRobertI 521
If your printer is sitting outside, yeah, absolutely
What temperature is it where you're actually trying to print though?
