yellowshark 153
Faberdashery(UK) and colorFabb(Holland) are two of the best filament manufactures in Europe. IMHO it is not worth buying cheap filament, especially if you are doing real production. In our business model the filament is normally a small percentage of the final price and so buying cheap filament is nonsensical - I guess it could be different for you. If you need a really smooth finish, like injection moulding, then take a look at the XTC-3D brush on coating, it is great! We are using it for an automotive external body part which needs to be spray painted without any further finishing and as smooth as all the other body panels.
Generally speed and quality are mutually exclusive; fast for prototyping and slow for production (unless the product is going to be hidden away and not seen).
I stand to be corrected but I think TweakAtZ can only be used once during a print, which may be fine. But if you have a geometry where the speed can changed at several points in a print without negative impact and TweakAtZ does not do it, the Simply3d will. It costs $150 and can provide a variety of benefits; there are people on the forum who use and would be better qualified than myself to comment. With the right geometry it is certainly a way of delivering good quality but reducing time and cost.
Unlike modern day computers 3D printing at this level is not plug and play. If you need to achieve high quality repeatable production then be prepared to invest many hours learning, especially if you will have multiple products that pose different challenges.
gr5 2,094
Too many questions!
The two printers print with the same quality as far as I can tell. I have one of each. But I usually use the UM2. The kit takes quite a long time to put together (took me about 40 hours - I guess I'm not very fast) and I ran into lots of snags but figured it all out eventually. So if you don't mind "wasting" 40 hours then go UMO I think.
If you are printing extra small things and want extra good qualtiy (e.g. jewelry) then you will want to get a .25mm nozzle which you can get for either machine now through 3rd party sellers.
PLA is a newer technology and almost everyone prints PLA these days but still lots of people are die hard ABS people. Both materials are fantastic. The main advantage of ABS is that it can be left on a car seat on a hot sunny summer day and it won't melt like PLA will. This is pretty important for many people. PLA is much easier to print with and less hassle and comes out looking a little bit nicer especially if you are new at this.
Many people on the forum print non-stop. It's fine.
Both printers are very easy to service. You pretty much need only one tool - a screwdriver version of a 2mm hex allen wrench and you can take apart everything on both printers with very few exceptions (I think there's one screw that's 1.5mm and that's it on the um2).
Customer support even expects you to take things apart as they often just send you for example a new circuit board.
Customer support is not great (well it's a bit slow but they are great people and smart) but it's typical of 3d printer companies and support is probably much better than makerbot.
Make sure you get an open system that uses open firmware and open slicers and such - no one realizes how incredibly important this is until it's too late. For example lulzbot is open. And ultimaker of course.
Don't worry about spares or precautions.
Could be as much as 2 weeks to get repaired if you are unlucky - more likely 1 week. Much faster in USA.
It's best *not* to plug computer in at all - ultimaker works best if it prints from SD card (included).
See? Here's where you absolutely need open source. There are plugins to Cura - "tweak at Z" that will let you change speeds part way through the print. It already lets you print infill faster than outer shell.
Download Cura for free and check it out. Get any STL model from thingerverse.com and load it into cura and slice it and look at it in slice view and slide the slider around.
software.ultimaker.com
For CAD software - if you are doing things like parts, covers, mechanical stuff get (it's free) "design spark mechanical". Like all cad it has a bit of a learning curve to be efficient. If you are more of an artist and want to model things like animals or people then don't get dsm! I forget what the most popular artist software is that is free right now. zbrush is popular but I believe that's expensive. Maybe meshmixer? or blender? or meshlab? (all free) I really don't know.
