4,297 -
33
Posts posted by Dim3nsioneer
Hope dies (at) last...
There is no UM2+ dual head. If you want dual extrusion you have to use UM2 (non plus) designs.
Schade, dass der Turm am Schluss abgebrochen ist. Ansonsten sieht es aus dieser Entfernung eigentlich sehr vielversprechend aus...
3dSolex and their resellers offer 0.15mm nozzles. They are officially for UM2s but can be used in an UMO with an adjusted fan duct.
@Labern is maybe THE expert for printing small...
Also, pictures from cute looking dogs or cats should not count...
@nallath: Interesting thoughts...
- 2
Difficult as Cura doesn't know about acceleration, jerk and maybe retraction settings of your printer.
Up to 120 deg. At what temperature are you printing? Without having it tested on HT higher temperature for the first layer usually also improves adhesion.
The question is where you bought both Olsson block and stainless steel coupler from. If both are from an 'official' source such as any 3dSolex or Ultimaker reseller it could be that an Ultimaker stainless steel coupler could be deformed due to its thin walls. In this case replacing the stainless steel coupler is the solution.
With some slight delay: Congratulations, @Eraser! This is what I call a well-deserved victory!
Interesting error message on the display. Trying to print outside of the valid area reminds me of a very early Cura2 bug (at a time it was called 'Pink unicorn') where movements to almost infinity happened. But please don't ask me about details of that bug....
So, as you are printing from sd card, the wrong gcode should be there... is it?
Actually I think your PT100 is out of range. Mine shows about 15°C lower than it should and I never got Ninjaflex liquid. Is the temperture reading stable?
I print Ninjaflex at 15mm/s or maybe 20mm/s but not faster. Also, if you have not yet, use some corn oil or similar (organic oil with high smoking temperature) to lube the Ninjaflex inside the Bowden tube.
I have a similar issue as @Rejutka when selecting a menu option such as the postprocessing plugin. Menu goes by click and then it's only moving the cursor...if you click again you loose the menu (Win8.1 and Win10).
Concerning TweakAtZ 5.0: There are two bugs which may prevent it from running properly (Thanks to @Murphy and @berndjm). They are fixed in V5.0.1 which will be distributed with the next Cura version. For all those who cannot wait until then: TweakAtZ 5.0.1
Density of different materials is different. And some filament is sold by lenght, e.g. Diamond Age or Faberdashery rolls.
Tweaking the first layer is possible with version 4.0.3 or higher.
Tilt it by 45° and add some simple supports so it stands... and use a brim...
@gr5: Use a different background color for the menu bar and insert breadcrumbs, then people should not get confused anymore...
Hmm...ok. Well, first thing I do if I get a new UM2; close it. Helps to stabilize the process, no matter if PLA, ABS etc. I have thus far not encountered the problem you describe in any of those machines. I print 90% PLA.
Sounds as if you get a new UM2 quite often...
Do you just close the front (with bubble plastic?) or do you have a more advanced setup?
@Teddy: Von wegen Anfänger und so... Fast hätten wir es Dir geglaubt...
Sehr schöne Aufstellung!
Noise usually consists of high frequencies (except e.g. 50Hz pickup or similar). As far as I know there is a software low pass filter in Marlin for the temperature reading. But it can be tested of course...
Colorfabb hat kein reines PLA; das Bio-Flex-Material ist ein Gemisch.
Upgrade your Ultimaker 2 with the Extrusion upgrade
in UltiMaker 3D printers
I guess we will know in one week from now why the availability of those kits is so bad.
