Mit der Kerbe kann man dann die Kabel bequem und ohne Knick am Lüfter vorbei ins Gehäuse führen.
Alternativ könntest Du auch das untere Gehäuseteil gleich mit eingebauten "Kerben" drucken...
Am Besten, bevor Du anfängst alles zu zerlegen...
du meinst direkt vom pi? oder muss ich ihn da an den PC stecken?
Von letzterem weiß ich, das es funktioniert. Firmware einspielen ist ja schließlich mein zweitliebstes Hobby...
Aber wenn Cura auf dem Pi läuft, müsste das auch gehen. Man muss nur in Cura darauf achten, das richtige Druckermodell auszuwählen, der Rest geht dann wie von selbst...
Hi Tinkergnome,
back here to ask you a courtesy ...
... is it possible to add two parameters (maybe) in Advanced -> Preferences -> Motion Settings -> unload/load speed ...
Hi @gpb01,
never fear, something like this is already planned. Unfortunately i'm quite busy atm, so please don't expect it too soon...
In addition: only the "fast speed" settings are not sufficient. There's also the acceleration, the rotation direction, the length of the bowden tube...
We also need support for the "+" models... - maybe more...?
I'm sure, we will see it some day, but i have no fixed date for you.
...does not charge a PLA filament.The motor filament motor is idling.
Sorry, but can you clarify, what exactly your problem is?
The "change material" wizard does not work anymore, or "Move material" or what are you trying to do?
More questions:
Have you disassembled any other parts (besides of the feeder), all cables checked?
The Olsson block was installed at the same time?
Does the nozzle heat up as usual?
Well I ordered a 35 Watt heating (from 3dSolex).
Now my question has to what to change in the firmware, and if so what?
Welcome to the forum!
You should adjust the PID parameters after installing the new heater. No other changes are needed.
I recommend the auto-tuning feature. Choose your preferred printing temperature and 8 or 10 cycles - wait until it finishes - and store the results afterwards. That's all.
Advanced -> Preferences -> Temperature Control
If you're interested: more about PID tuning at the RepRapWiki
Da der Fehler bei Dir nur manchmal auftritt, hätte ich noch einen anderen Verdacht, dem man mal nachgehen könnte.
Der arme kleine Arduino hat nur sehr begrenzten Arbeitsspeicher. Ich weiß nicht, wie der Martin seine Version kompiliert hat, aber vielleicht hat sich der Engpass damit verschlimmert...?
Du könntest vorläufig vor jedem neuen Druck den Drucker einmal "durchstarten" (also kurz aus und wieder einschalten). Und dann weiter beobachten, ob das was verbessert.
Viel Glück!
- 2
And every time I try to learn (like for the past hour) I get incredibly frustrated and quit trying again for a few months.
The same here... it always ends up between and
My solution: use the Poor man's openscad screw library or the OpenSCAD threads library - generate the needed threads with OpenScad, export in stl-format, import and use it in FreeCad...
Good enough for me.
- 2
Lediglich 'Move material' scheint eine reine Service-Funktion zu sein. Da muss man aber wohl warten bis die Düse aufgeheizt ist und zu drucken beginnt. Dann schnell mit 'Pause' unterbrechen, 'Move material' ausführen und dann den Druck fortsetzen.
Nein, nein - ich meinte das "Move material" kannst Du ganz in Ruhe vorher machen (oder besser gesagt: zwischen zwei Druckaufträgen). Dabei wird die Düse ja aufgeheizt, also warten bis ca. 200° erreicht sind, und dann so lange manuell Material fördern, bis Du sicher bist, das es an der Düse "ansteht". Das bleibt ja dann (hoffentlich) so, bis der nächste Druck startet - und dann sollte ja auf jeden Fall genug Vorlauf da sein...
(die Heizung geht auch wieder aus, wenn die Funktion verlassen wird - da ist nichts weiter zu beachten)
BTW: ich glaube in der "Pause" steht "Move material" sowieso nicht zur Verfügung, oder?
Nur, um das nochmal abzuklären:
Du verwendest Cura als Slicer, hast den richtigen Drucker ausgewählt und auch sonst nix an dem Maschinen-Profil verstellt?
Die normale "Aufheiz-Phase" am Anfang des Druckes findet aber bei Dir statt, oder?
Ich meine: wo der Druckkopf nach vorn links fährt und im Display steht "Heating up..." - oder so ähnlich...?
@tinkergnome ist superflott im Antworten und hat das Ganze ja gebaut
...wenn ich getaggt werde, finde ich das auch hier...
Diese Firmware habe ich vor kurzem aufgespielt.
Dann kontrolliere vorsichtshalber mal, ob die Einstellungen hier noch stimmen:
Advanced -> Preferences -> Print area
Das sollte dem hier entsprechen:
#define X_MIN_POS 0#define X_MAX_POS 230#define Y_MIN_POS 5#define Y_MAX_POS 230#define Z_MAX_POS 230
Es bleibt also die Frage, was kann ich mit Cura und Ultimaker 2 machen, dass es nicht weiter zu Drucken kommt, bei denen am Anfang kein Filament fließt?
Super, dann ging's ja doch mit dem Englisch...
Vorschläge:
- Falls noch nicht gemacht: neueste Version der Firmware installieren (Cura hat einen Menüpunkt dafür)
- immer mit ein, zwei Zeilen Skirt drucken (ehrlich: ich hab keine Ahnung, wie das in deutsch heißt... - aber Cura hat eine Option dafür)
- wenn unsicher ist, wo das Material grad steht, einfach vor dem Druck mit "Move material" manuell "primern"
Ganz ehrlich: ich hatte so ein Problem nie - (auch nicht in meinen Drucker-Anfangstagen) - irgendwas muss bei Dir anders sein...?
@niyoki: Danke! Das hatte ich dann auch entdeckt und unten Martin gebeten, mir auch den Code zu senden. :-)
Ich hab grad gesehen, dass Du einen Ultimaker2 hast - es wäre einfacher, wenn Du das mal in Deinem Profil einträgst...
In dem oben genannten Thread geht um den Ultimaker Original - das wird Dir vermutlich nicht besonders viel helfen....
Hhmmm..., wie geschrieben, wenn das Filament erst einmal austritt, läuft es ab da einwandfrei einen ganzen Druck lang. Da sollte doch der Feeder Ok sein, oder?
Können wir nochmal ein Stück zum Anfang zurück....?
Von welchem Drucker ist überhaupt die Rede? Welche Firmware-Version?
Nur die LEDs ein ausschalten per Gcode mit M42 Sx, funktioniert leider nicht, da hängt sich der ganze Drucker auf und muss neu gestartet werden.
Letzteres ist ein Firmware-Bug. Falls es noch ein "normaler" UM2-Extended ist (ohne "plus"), dann sollte das mit Version 15.04.3 (oder höher) behoben sein.
(Cura 15.04.4 herunterladen und Firmware-Update einspielen mit "Machine -> Install Default Firmware")
Ein paar weitere Fragen:
Was ist das für ein 3D-Modell? Die Wandstärken sehen sehr dünn aus... (evtl. zu dünn für Cura?)
Wie sieht der Layer-View in Cura aus? Kannst Du davon auch mal einen Screenshot machen?
So wie das Ergebnis aussieht ("Under-Extrusion"), kann es auch eine teilweise verstopfte Düse sein. Wer weiß schon, was mit dem Drucker vorher gemacht wurde - vielleicht sind noch ABS-Reste drin?
Wenn ich von unterwegs sehe, das der Drucker Murks macht, drehe ich ihm einfach über die FritzApp den Saft ab (Steckdose AUS).
Hast Du da keine Bedenken, das irgendetwas Schaden nimmt, wenn Du einfach so im vollen Lauf den Strom abschaltest?
Ich hätte da Angst, das irgendwelche Transistoren* (von den Ausgängen der Heizung oder Lüfter) frühzeitig den Dienst quittieren, wenn man die bei voller Leistung einfach so ausknipst... oder ist das heutzutage kein Problem mehr?
*) ich nehme das mal als Sammelbegriff für "kleines elektonisches Teil"...
Außerdem wird das Hotend sofort nicht mehr aktiv gekühlt und die Restwärme vom Heizblock hat genug Zeit, sich über den PTFE-Coupler herzumachen...
Ich glaube ich hätte da Skrupel vor so einer Lösung...
Zuerst mit Octoprint den Druck ganz geregelt abbrechen - und die Steckdose erst ein paar Minuten später abschalten... das könnte ich mir schon eher vorstellen.
Maybe there is another location for these values than Configuration.h ?
The standard firmware uses the min/max values from Configuration.h only as the "Home" position, but all other coordinates (for buildplate leveling, heatup and pause) are fixed and hardcoded elsewhere.
That's quite annoying for users with modified hotends (like you...) - that's why i changed it recently for the tinker firmware. It's just an attempt to make it a bit smarter for all the tinkerers out there...
The display shows a negative number after I move some material through the nozzle.
Am I to deduce that the extruder is running backwards, or ???
I think so...
There are already plans to make the stepper directions easy configurable, perhaps next months or so...?
For now: swapping the cables should be the easiest option. If this doesn't work, you can still compile a customized tinker version...
Edit: i'm too slow...
My newest challenge is figuring out how to modify settings somewhere so that the right-side fan shroud doesn't smack into the side of the enclosure when I do things like level the build plate. I am assuming I need to search for a Max X or Y setting somewhere in the firmware and recompile, but not sure...
Here is what i did for the y min and the x max position:
- use "Advanced -> Expert functions -> Move axis" to figure out how far you can move the axis ("Home" the axis first)
- use "Advanced -> Preferences -> Print area" and adjust the min (resp. max.) value (using the determined values from the first step)
The heatup position and the positions of the buildplate wizard are calculated from these values.
Regarding the fan control: i followed this approach - works flawless so far.
load the gcode into Cura
The common "File" -> "Load model file..."
...can also be feeded with a *.gcode file.
Donc pour moi, une buse a 300° et un plateau chauffant sur la 2go <3
Y at-il déjà...
Hello ! The TF2K 300C is fine just to ABS but when you switch to PLA then I'll have to remove and replace the TFT 255C!
Sorry, but i guess you got it wrong...
The (so called) "TF2K 300C" combo consists of an "TFT 255C" plus an additional "I2K" wafer chip. And it works fine for PLA.
"Only for ABS" belongs to the "IPM Coupler"
Those things happen all the time - and not only with consumer products...
Personally i would try to stay calm and keep it in perspective, look at the benefits...:
- let others struggle with the teething problems of the new model
- evaluate the upcoming reviews first
- later i can decide if i have a need for the upgrade kit or not...
In the meantime: make use of my "old" model, wait and see..., and don't fret...
(just my 2ct.)
If you can go to 300 in the default setup thats very practical, in 15.10.2 it was still 260.
I don't think the brass block will be the issue, you'll have to try the 3dsolex options for high temperature replacement for the PTFE.
I compiled the recent release for a max. temperature of 300°C. You will need it, if you want to verify the 300° promise from Carl...
Look for "TF2K 300C Combo"
I agree with Arjan:
i don't think that the brass block will be affected, but if you use the higher temperatures with the standard hotend, the PTFE coupler will degrade quite fast.
However I'm getting the dreaded 'Heater Error - Contact Ultimaker' now!
The printer uses a new PT100 sensor and the E3Dv6 and printing with ColorFabb PLA.
The "Heater error" is triggered if the nozzle heater is fully powered for more than 30 seconds and the temperature does not increases at least by 10°. It's a security feature to preserve you from burning down the house, if the temperature sensor doesn't work properly...
I was told, that the E3DV6 has a bigger thermal mass than the default hotend. The heating takes a bit longer, especially if you use higher temperatures - so this may be the explanation.
..and the reason why i recently made the period of time adjustable. You can try to increase the value a bit, until the error disappears. But please keep in mind the security aspect - i don't recommend to disable it completely!
Advanced -> Preferences -> Heater timeout -> Period of max. power
Tinker Firmware
in Français
It doesn't seem so... : Tinker_16.01 LCD freeze
Unfortunately it's not reproducable (at least for me)...
I'm sure we find it out - someday...
