Dim3nsioneer 558
As I happen to have both UMO and UM2 I can tell you that I mostly use the UM2. However, I decided to upgrade the UMO with the HBK as I have some plans for this machine as well.
And yes, there is a significant noise level difference; it's just the wooden frame of the UMO which makes it extremely difficult to get the sound level somewhere near the UM2.
I think the UMO is the right choice if you want to significantly modify it, e.g. with a different hotend, direct drive, cross-flow fan, etc. If you just want good prints, buy an UM2, extended or not. If you want really good prints, add an Olsson block to the UM2...
I don't know if upgrading the UMO electronics to the 2.x board makes sense. Be aware you have to replace the hotend temp sensor.
neotko 1,417
My personal opinion it's that if you upgrade pulleys to gt2 and change the extruder to roberts with the same um2 motor (0.9-400steps) (this kills the noise big time) and you place a noise barrier so it doesn't reverbs on the wood. Then you can have a very very nice printer. And much cheaper.
But I use umo+ so the board it's different. There is also a post about changing the stepper chips to make the movement silent.
Edited by GuestLink to post
