what did you clean the build plate with?
Make sure you use isopropyl alcohol.
What nozzle temp are you set at. some times if its to low its to gummy and drags with the nozzle
Would this be good?
http://www.wickes.co.uk/Super-And-Glass-Stainless-Steel-Cleaner-750ml/p/114455
And between 200-220 with no luck:(
Thanks for the reply! Apreciate it
Labern 775
