cloakfiend 995
I'm loving it! the quality is much better and i get my print quicker!! more internal stringing but better overhangs and overall quality for some reason, i may try 0.5 instead of 0.6 as i see some non important anomalies. i had a feeing it was just extruder speed related rather than diameter related as all the surfaces are perfectly smooth. Seeing as the um2+ had heavier objects compared to the um2, is it overextruding compared to the um2?
So basically if you see this, you are over-extruding, definitely better than under-extruding!!!
I'm now very happy with my upgrade!
EDIT: the flat surface lines under closer inspection indeed do not connect as ultijan said, but walls connect, so for organic stuf, this is a fantastic time saver, but for flat horizntal stuff no good if you want it perfect. Is there a way of increasing the flow in cura to increase it a touch as i dont like using that setting on the pinter? i only adjust temps live, flow and speed i stay away from ad they make weird noises when you change them.
Edited by Guest-
4
Top Posters In This Topic
30
13
11
11
Popular Days
Nov 4
34
Jan 28
19
Nov 6
16
Jan 29
15
cloakfiend 30 posts
SandervG 13 posts
LePaul 11 posts
KevinMakes 11 posts
Popular Days
Nov 4 2015
Jan 28 2016
Nov 6 2015
Jan 29 2016
Posted Images
ultiarjan 1,223
Next to the speed it's also determining the path..... wider nozzle is less lines needed in a surface.
When you run a 0.4 at .6 settings your surface lines will not connect....
