It won't work on umo without some serious mod. For example it would need a shorter peek and the 4mm dia heater. Also on umo since it uses 18v the heater shouldn't work. On umo+ it would need the peek modded and the new heater. Or an totally different redesign. Anyhow it's just my theory...
Also the only advantage va the umo heater it's that it's made of brass and has a more symmetrical design. But also the heater on umo it's 2-3 times less expensive (if you don't count the nozzles...)
SandervG 1,499
This is an example of what an upload should look like.
Edited by GuestLink to post
SandervG 1,499
I'll do a test print here during the week and let you know. So you can start participating and if you happen to win we'll find an appropriate prize if it doesn't work.
Looking forward seeing your entry!
