I would also just order a new glass plate.
I have used build tak before, works quite nice but it is not a build plate.
It is a sheet of tape, an alternative to blue tape. You don't necessarily need blue tape on your Ultimaker 2, so why would you use build tak? My point is it could be an alternative for adhesion, but not for the build plate.
Same goes for the blue tape obviously.
I have tried things like gecko tek and flex 3D, not sure if I have tried this exactly.
This can be used as an alternative to the glass plate, but I didn't think it worked better.
The point is you can bend it so your print comes of faster, but I have always worried about how to ensure it became 100% flat again. From my experience adhesion was also not as straight forward.
Don't know about the rest, but if you would ask me I would recommend to use a regular glass plate
DidierKlein 729
I have tried BuildTak (only printed PLA on it), and it sticks nicely. I have done a couple of prints on it and it's still in perfect condition.
You have to level the plate slightly higher in order no to squish the first layer (or it can destroy the buildtak).
It's a good product to replace blue tape, you don't have the lines between the tapes and it sticks better to the buildplate.
But if you have a UM2 i would go for a new glass plate, it works pretty nicely for most of materials
