Hi thanks for responding
I'm leveling the 3 spots where the adjustments are
I've gone thru the USB cable-calibration for the Z stop after the upgrade. I never got the '4 squares' the documentation stated I would get...but I got the perimeter print out. (The documentation really needs some updating)
Top Posters In This Topic
25
12
10
16
Popular Days
Jan 21
25
Jan 26
14
Jan 29
14
Jan 28
13
LePaul 25 posts
yellowshark 12 posts
cloakfiend 10 posts
neotko 16 posts
Popular Days
Jan 21 2016
Jan 26 2016
Jan 29 2016
Jan 28 2016
Posted Images
valcrow 144
Are you leveling with the nozzle on top of the 3 point screws? You shouldn't be leveling the back left and right or you'll go insane since you'll be leveling 4 points with 3 point leveling.
This is what I would do:
Level the Center back position first, with the nozzle directly over the screw. Tighten the screw until you feel a bit of the spring tension. You want this somewhere in the middle in terms of tension so you can loosen or tighten later.
Adjust your Z-end switch so that it approximately clicks at that position.
Now fine adjust the leveling screw in the center back so that the glass is paper length away.
Do the same for the front left and front right corners (again directly over the screw)
This should get you pretty level. Print this pattern and fine tune the screws until you get your nice smoosh, and proper sticking. (scale by 2x) https://www.youmagine.com/designs/bed-level-pattern
