The part that confuses me @zurichch it's that you say 1.5.7 board, if you have UMO+ you have a 2.1.X board
Also, I would just try to open old cura 15.xx and flash with that firmware. If it doesn't connect I think I did read long ago an user that had that problem and fixed it by turning off/on until cura did connect to the printer. Also you tell on what OS you did this, for example if it's mac I would try to reset the PRAM before trying again.
Also, I don't think you really need to update umo+ firmware to use the calibration of cura, you can skip that.
Edit..
Ok you have a UMO with a Bed kit, not a UMO+ the part you say "I did with the Ultimaker Origianl + firmware" did confuse me. Can you try to flash with the old cura and the UMO with Bed kit firmware? (not umo+)
Edited by Guest-
2
IRobertI 521
Sorry about the late activation of your account.
Have you tried simply running the firmware update again? If something went wrong during the update it can happen that the printer appears dead but it's unlikely that you actually bricked the controller completely.
zurichch 1
I have a similar problem on my Ultimaker original + with a heated bed. It was working fine until I wanted to relevel the bed.
After updating Cura, I was prompted to update the firmware, which I did with the Ultimaker Origianl + firmware. Then nothing worked after that. It still has power but the display is blank and Cura will not communicate with the Ultimaker anymore.
I'm not familiar with reflashing or installing the boot loader on the Ultimaker version 1.5.7 board, which I'm only guessing, I have to do. Can anyone please give me a clue where to start? I need to get the Arduino to start talking again.
