Did you try to turn of brim and skirt?
For the object that need to be printed, some support structures are required.
Regarding the build space: Yes, I have used several test objects with 223 x 223 x 1 mm, 222 x 222 x 1 mm and the like when I tried to figure out the real build space. The useable space of the UM2+ is nowhere near the specs. I wasted months with this crap.
To print the object, the UM2+ would probably require modifications of the firmware or whatever, or it might work with an UM2+ Extended, I don't know. Since nobody is willing to tell me the "real" specs of the UM2+ Extended, I'm not going to buy one for "testing" purposes. That's why I'm looking for a service provider. I don't care about the brand of the printer, I just want a useable result.
Greetings, asb
ultiarjan 1,221
