My goal is primary acoustic ( We have the printer inside our office next to our working stations) and secondly, is a am closing the printer anyway for acoustics, let's do it the right way and making it the best thermally also. We want to print with CPE+ for example.
I was thinking a full enclosure around the whole printer. Using Bosch aluminum frames. With plexiglass. Isolating foam on the sides. and 2 doors (Front and back). A top removable panel just in case. The hole thing bolted over a cabinet with all the tools and filaments under it. And additionally a computer fan (low noise) with thermal control of the inside case to avoid overheating.
The whole system is next to windows (here in Switzerland it gets cold!) so for now when we print we can't open the windows because we worry of affecting the printing.
Also avoid to much exposure of the printer of the sun. (Machines don't like UV )
SandervG 1,522
I believe the specs say the ideal operating temperature should be between 15º and 32ºC approximately, so I think that is what you should aim for. I believe @UltiArjan might have ran it around 50ºC but I am not entirely sure what his experience was.
Maybe he can tell us.
It definitely make sense to close the front. Do you want to close the top for accoustic reasons, or to improve your build quality?
What filaments are you (trying to) print with mostly?
