Man, I'm out of the loop for a few months, and find everything changed. (for the better, Daid; Awesome.)
Anyway, I had a few thoughts on how to improve on the awesomeness:
I use the "Fan speed min - max" setting. My fan (not original) runs happily and very quietly at around 25 - 28 %, however it won't start at anything below 45%, and not always then. This is a problem in combination with "Fan on layer (1)" and the project planner. [edit] A simple solution would be to give the fan 1 second of full power before settling on the given percentage. [/edit, added proposed solution ]
In the project planner, I for one would like back the ability to manually place parts. I would also like the ability to override if parts are placed to close together; If printing really low parts one cm in each direction is plenty, and changing the "Machine head size" every time is tedious. I Imagine a popup saying something like
"According to the current settings, the machine head will crash into printed objects x, y, z [just pull the names of the red ones], are you sure you want to continue? Do so only if you know what you are doing."
Being able to designate a 3 dimensional machine head size comes to mind, but I don't know if that would be practical...
Also, why is the project planner in its own separate window? Couldn't we have the ordinary Cura window, and the side panel from the project planner available (collapsible?) on the right? This would be more intuitive I think, and enable a more harmonious workflow... As it is now, I find myself flipping between sometimes up to 5 Cura windows (Project planner for setting up; main window with all the settings; The progress window for slicing the next print; The currently printing window, and sometimes one of the "Expert settings" "Preferences" and "Project planner preferences" windows), which is a bit... messy. I have dedicated a computer with dual monitors, and I still have to flip back and forth a lot.
Further, is there any way of looking at the layers in the project planner? I can't seem to find any way of running gcode generated at some other time either, or getting at the printer controls (jogging, temp etc) without first slicing some model, and then printing that.
If I'm giving you a hard time it's only because I really like the stuff you're doing
Daid 301
Arrow key control has been suggested for layer switching, which makes sense and I will add soon.
