This issue on github has a lot mot discussion about this exact issue:
- 1
I see. Well easy answer use old cura.
On S3D controlling what gets infill and how is a matter of adjusting 5-7 settings depending on the situation the user has the control of what happens 90% of the time. And if all fails you can just split the too layer and change the settings for that alone or for a part of the object if you plan ahead.
Thanks for the replies. I'm going to do some testing over the weekend. The text is really small right on the limit i feel. Thanks.
Easy solution.
Split the object in 2. One the base the other the texts. Merge on cura, select the text object and assign a lower nozzle size to make the extrusion on that area finner. Play until it fits and also, check the gcode view before printing to see if there’s gaps.
Easy solution.
This is already what I do. I have the base printed with a .4 and at a pretty fast speed. The text is done with the .25 with the settings stated in the first post. As you know this saves a huge amout of time with printing. Thanks for your help
could the 'ironing' function be of any help? and use another pattern to go over the top surface. (could also make things worse, but if you don't try....)
What you achieved already looks great for such a small font!
gr5 2,230
@neotko might now how to fix this although he usually uses s3d and not cura.
The basic issue is that infill is trying to fill in those holes but basically failing. There are some new settings in cura and I think one of them tries to fix this exact issue but I don't know much about it and don't understand it.
