I would stay away from faber. They haven’t improved their formula since the start, their filament size consistency is ok but color shifts from pack to pack. Also they never solved the issue of micro dust particles inside the filaments, and sounds silly but affects more than what you expect, specially for pastel colors.
For precision get smartmaterials (spain, super quality) fillamentum and for a safe bet colorfabb.
Also try to buy pva boxes (easy to diy) to keep pva dry. If you planto get nylon or much pva, there are food dryers that can recover a spool overnight They are quite cheap (compared to what UM charges for a pva kilo)
So. Tupperwares, desiccant, plastic zip bagges also help to pack filament after use (many big ones for food with zip are cheap on amazon).
- 2
gr5 2,184
Well you could slice a few things in cura which is free and you will need it anyway to use your UM3. That will tell you how much filament you need - typically in meters but I think it's possible to get it in weight. Filament is sold by the weight. For example UM sells .75kg spools. Some companies sell 1kg or 2.2kg spools.
I recommend you try faberdashery filaments - I've never tried them but hear great things and they are in the UK. Also I recommend UM for the PVA as their formulation doesn't absorb water quite as fast (keep PVA very very dry).
I also recommend you start out with prints that take less than 3 hours - start small! You will learn more faster. It took me about 100 prints before I really understood all the main issues and was getting perfect prints every time. This will come much slower if you are doing 20cm multi day prints.
penguin_k 0
Thanks for your reply! This will be really helpful to me.
So, to check that I've understood the basics:
- Buy non-PVA filaments from faberdashery (I just checked it out and it looks perfect!)
- Buy PVA support filament from Ultimaker themselves (or at least from a reseller)
- Start small
Also, which diameter filament do I need? Faberdashery offer 1.75mm or 3mm and the Ultimaker website says it needs 2.85mm :/
Edited by GuestLink to post
