18 minutes ago, gr5 said:I don't think your part needs support. You might want to just skip the pva. I'll read your whole post later but also know that Nylon is very tricky to print. Once you know all the tricks it is easy. But until then it's frustrating.
Thanks gr5 for the reply. The model has internal horizontal structures, which I assume they need support. I can definitely try to print it without (once the hardware issues are fixed, that is). Do you think the Cura parameters are OK?
gr5 2,024
