The corrections are depending on different parameters like layer height, speed, temperature, and a lot of other parameters, so when you make try and error rounds to find your setting, do it with the settings you want to have for the final print.
Of course UM could make this "automatic" in Cura, but due the fact, thats depending on so much parameters, it will not be so easy, to fit all circumstances. But yes, they have everything under control and it would be more less possible.
On the other hand, I have a colleague here with an Anet A8 and watching him, modifying, tuning and operate his printer, then you actually see how small the UM problems are. Working with such a China thing is really pain in the ass, but ok, they cost a fraction of an Ultimaker.
1
P3D 46
Thanks for your feedback! Correction in CAD is far from ideal in our companys workflow unfortunately.
For now, I made the adjustments in CAD, and while there is still some error (seems to be non-linear?), the accuracy is OK for the intended use of the part.
In my opinion, this is a prime example of what *should* be corrected in a material/printer profile. This should not be too difficult for Ultimaker, as they have in-depth knowledge of their materials, hardware and software. In other words, they are in full control of all the parameters.
A turn-key "print the STL file exactly as it is" solution would be a huge differentiator, especially for industrial customers
On the other hand, they don't even seem to bother about simply ticking a box that is already there, like disabling the combing for CPE....
Sorry if I seem to be quite negative, I really like the S5 for its flexibility and general reliability, as well as the very useful material range. However, I expected much more from the combination of HW/SW/Materials coming from a single manufacturer.
