14 minutes ago, Smithy said:To check if really everything is fine with your nozzles, heat up the print cores, open the leaver on the feeder and load the filament manually. Then push gently the filament forward to extrude some material. If it works, you have a problem with the feeder, if not, you should check the Bowden tube and the print cores again.
Did it just now material was extruding without me using any force just gentle push.
Smithy 1,135
To check if really everything is fine with your nozzles, heat up the print cores, open the lever on the feeder and load the filament manually. Then push gently the filament forward to extrude some material. If it works, you have a problem with the feeder, if not, you should check the Bowden tube and the print cores again.
