I'm not talking about the bridging. I'm talking about all of the little spikes protruding from the vertical parts.
Here are some closeups with the areas circled.
I noted in the tags, but didn't mention in the text that this is being printed on an Ultimaker 3. And I get this whether I'm using support material or not.
Edited by johnseAdded being printed on UM3
gr5 2,210
I don't see any stringing - or barely any. Your retraction looks good.
Maybe what I call "bridging" you call "stringing"? Bridging is where you are bridging across an air gap. Yes your part doesn't look great there but that's probably the best you can get with Nylon alone. If you had a dual nozzle printer, PVA works very well with Nylon. But I can't help you on the bridge settings - PLA is the nicest material for bridging and even PLA won't get much better than what you got. Usually.
Although @smartavionics has a version of Cura that lets you play with a lot of the bridge settings. You could try that version of Cura - search for "bridge" in the settings.
https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0&lst=
