Yes I'm guessing you are right and you shouldn't have saved your profiles. Not sure. But anyway there is a folder - I forget where - on windows I think it's in %appdata% or roaming or something. It has all the profiles for cura in there - if you delete everything in that cura folder (in %appdata%/cura - or similar) then restart cura it will create the proper default profiles automatically upon launching cura.
gr5 2,196
Go into PREPARE mode. Across the top (just under "prepare") on the left core click there and instead of having it auto detect your filament type, select the filament manually.
I suspect the intent profiles are only for PLA and only for the AA 0.4 nozzle but maybe there are more. "tough pla" might not have the "engineering" profile but you can print TPLA with PLA settings just fine.
Roffe 0
Many thanks gr5.
Problem partly but not entirely solved, unfortunately.
I found that for some reason, Cura 4.4.0 had changed printhead 2 to AA 04 (PVA was selected). When I changed back to BB 04, I can see three profiles - Fine, Normal and Fast, regardless if I choose Tough PLA "generic" or "Ultimaker". When I try PLA for printhead 1, I can also see the "Extra fine" in addition to the others, "Fine, Normal and Fast". No other profiles can be seen.
During installation of 4.4.0, I chose to keep my profiles. If that is the problem - can I erase all old profiles in 4.4.0?
(In Preferences/Profiles I can see Extra Fine, Fine Normal, Fast under Global settings. Under Extruder 1 and Extruder 2, no profiles are found).
Edited by RoffeLink to post
