1) How realistic is the uptime of this printer? Lets talk specifically PLA & PVA. Both from Ultimaker. Does it really actually print flawlessly and very reliably? Or, is there actually still a lot of tinkering and problem prone processes that need to be navigated? For instance here is an article where a test reviewer encountered problems with a false-positive "out of filament warning" every-time they printed with PVA.
Apartfrom cleaning the printer out from time to time, and doing the normal oil of rods and stuff i have had like 99% up time in the past two/three years and my printers run almost 24/7. PVA can be tricky so its best to get a dry box to keep it dry why printing, polybox is good for this, also dry it out before printing if its not been used for a bit of time. Personally i use breakaway now days because it gives the same underside for overhangs and more supports are in places i can access to remove more easy.
2) How reliable is the remote access? Always up or it's kind of a hassle with spotty connections and you don't really use it 6 months in?
When at work i'll check the progess of prints to make sure they all going fine, never had a problem and thats with using 4g on a phone to access it.
3) Did your printer arrive ready to print or did you have issues with it being damaged or out of alignment?
All 3 my printers arrive ready to print aside from the normal loading print cores and filament, they come in boxes designed for the trasport of the printer (they come that well packed that it gives my a good amount of free packing for orders i print)
4) What has been the biggest problem with your printer so far? Have you been able to fix it?
Not really had any problems, apart from the normal user error with settings and that.
5) Did you get the extended warranty? Was it helpful or worth it?
I trusted the machine to work and last and thats why i paid more for a printer over other brands, because i like to have a machine just work and not pay less and find self having to spend time to get a machine to work.
6) Do you update to the latest firmware or wait for a while because this process has lots of errors that make it worse?
I personally update when its out, you can roll back firmware so its not really a problem, plus the more people use a firmware the faster any bugs get found and fixed.
7) After owning one for a few months would you buy another? Do you already have multiple? Do you wish you would have bought another model or brand?
I got a s5 after owning a few flashforge printers as i need something bigger and could run 24/7 for days on end, just under a year later i got a 2nd s5 and then this year i got the s3 also.
8] How often do nozzles get clogged? What happens when a print core is clogged? Do you have to buy a new one? Can you fix the existing one?
Use good filament and keep filament and the printers in a clean area and you be fine, only time i have had a clogged print core was when i tired a cheap amazon basics spool as it was the only thing i could get at the time due to covid. Easy to fix with some ultimaker cleaning filament and following the hot and cold pulls on the printer menus, something you should do from time to time alway to keep the cores clean.
Smithy 790
I have a lot of printers, UM2+ Ext, UM3, S3, S5 and also a Prusa. I can say, nothing is more reliable than the UM printers. The Prusa is nice for kids or for pure hobby usage, when it works it prints good. The MMU is another story, I sold it after 2 weeks, the concept or idea behind is not bad, but the part itself is shit and cheap. And it works only with much luck without any user intervention. I had only one print job which was running fine from the start to the end. For all other jobs I got alerted every few minutes.
Yes it is very reliable, I have rare issues and when there is an issue, it was my fault. Regarding PVA it is very important that you keep the PVA spool really dry and if you print a lot with PVA, also during printing. Most PVA problems here on the forum are due to bad PVA spools. PVA absorbs quickly moisture from the air and then gets soft and sticky. Both are not the best parameters for the filament sensor. So if you plan to print a lot with PVA consider to buy the S5 Pro bundle with the material station or another external solution of your choice.
I use it not very often because I don't have the need, but when I am away and need to do something remotely, the Digital Factory works fine, without problems. Every other print job is sent directly via local LAN to the printer. I don't use the wifi connection, so I cannot say how stable it is. Some user reported problems with the wifi, but with an ethernet cable I have no issues.
Yes, ready to print, no problems. I know you mean the one post in the forum, but this is a single case where the printer was not in the original package as far as I can remember, it was a used one. The printer is well packed, there is nearly no chance that something could be damaged. But if the delivery guy throws the printer of the car from 1.5 meters, then nothing will 100% withstand.
To be honest I had no serious issues yet with the UM printers and my S5 is 2 years old now. I also print still with the print cores that came with the printer and I have cleaned it one time in these 2 years. (ok maybe I am too lazy and I should do it more often, but I have no problems)
No, I don't have it.
I always update to the latest firmware and never had any issues with it.
Yes as already said in the beginning of my post. I also never looked to any other brand, because I like the printers itself and also the whole ecosystem. Everything works fine and easy. For example when you want to print with another filament brand which is probably not as easy as PLA, I check the Marketplace in Cura, decide to buy material xyz and then load the profile from the marketplace. The profile is automatically synced to the printer and you can start your print job. I never printed or played with temperature towers or such things.
The journey to the Prusa was a test and because I was interested what is behind the hype. But it is nothing which is comparable. And personally I don't like the 1.75mm filament, it is often tricky to handle and you get quickly tangled spools. It is also a bead idea to have 1.75mm and 2.85mm printers, because you need both filaments on stock.
Not very often in my case, but it depends how often you change material. When you print a lot with different materials than it can happen, especially if these materials need different print temperatures. So in that case it would be better to use dedicated print cores for specific materials, i.e. one for PLA and another one for ABS. But when you should have a clogged print core you have guided instructions in the printer menu to clean the nozzle again.
The BB print core for PVA needs a little bit more attention, but when you clean in proactively from time to time, you should be fine.
The switchable print core concept is also fine to keep the printer up and running. If you really have issues with a core, just swap it to another one and you are back in business. The clogged core can be cleaned later when you have time.
I hope I could help a litte bit.
SandervG 1,423
Hi @sensebellum, thank you for your message! Hopefully you will get a lot of input.
Ah yes, the promise we regrettably couldn't fulfil on the Ultimaker 2. We still regret it to this day, and learned many lessons. Are you also looking for more print capacity or only to enable dual extrusion? Do you think you will use PVA mostly, or other support materials or build materials? Depending on your answers, the community at one point united and build this modification. It was very well received, but it does require modifications with the attached risks. So if reliability is high on your agenda (and the use of PVA), I might not recommend it. But I wanted to put it out there as an option.
Regarding the Ultimaker S5, some questions I can not answer as a user, but as an Ultimaker team member I can try and answer some.
The uptime is good. Just with any technology, there can always be a hick-up but often they can be solved quickly. PVA is a rather sensitive material, which needs to be treated as such. If you don't treat it well, it can give you difficulties. Particularly due to the moist it attracts from the air. The issue you mention from 2018 with the flow sensor has been addressed in an earlier firmware version.
We had some issues during the first months after being launched where connectivity sometimes dropped, but this has also been addressed a few firmware versions back. We do recommend to connect it to LAN, since that will always be more stable than wifi.
Next few questions are more aimed at users I think..
I like to think they rarely clog. If they do, we have cleaning filament to unclog them. Our print cores are really reliable and have a very high uptime.
Hope this helps! Perhaps you can also describe what you intent to use it for, so people can also give specific tips to keep an eye for, or give recommendations.
One thing I would like to add, as shown in the previous answer regarding flow sensor, connectivity and the responses you get in general, is that we actively support our products and you can expect to receive updates throughout owning one. This community is also a great place if you want to learn more about our products, 3D printing, or how to improve your 3D prints. I believe this adds a lot of value to your experience of owning an Ultimaker 3D printer. You are never left by yourself.
Thanks again, have a great day!
