Hi gr5,
Yes it is PT100 sensor but on bULtimaker there is loads of PT100 sensors, I need to know which I should choose.
Also I have installed the e3d board that supposed read the pt100 from head and send reading to the board, but I am having 68ºC at room temperature and it doesnt change.
I flashed it with pt100 but the only sensor that works is the thermistors that came on chinese print head, and both reads ok, bed and head, I am considering using those thermistors to get my temperature if I couldnt find the right ones on bULtimaker.
I dont think need change the board, I saw guys that made these upgrade but I cant contact them to ask.
22
17
17
12
Popular Days
Nov 18
18
Nov 20
9
Nov 15
7
Nov 24
4
Torgeir 22 posts
Juliogdiana 17 posts
3dprntz 17 posts
gr5 12 posts
Popular Days
Nov 18 2020
Nov 20 2020
Nov 15 2020
Nov 24 2020
Popular Posts
Juliogdiana
Got the printer fully working now with ultipanel controller, hot end temperature works perfect with amplifier e3d pt100 board, resistor R23 cut and firmware with sensor 20, same as um2. I
Torgeir
Just checked your possible choice of temperature sensors, -and a PT100 with a 4.7 Kohm is possible to use! Here it is: Good luck. Thanks Torgeir
gr5
Almost surely because you need to add the 4.7k pullup resistor. I think using the thermistor is a great solution. The pt100 isn't more accurate but it can handle higher temps. Thermistors get damag
Posted Images
gr5 2,203
I'm not sure you can. The UM2 head normally has a PT100 sensor. Can you confirm that detail? If you measure the ohms it should be about 109 ohms +/- 5 ohms at room temperature.
The UMO heated bed upgrade allowed you to use a PT100 sensor but they added a second circuit board to allow you to measure the temperature with a PT100 and the 1.5.7 version board. The UMO+ uses the V2.X circuit board which has extra electronics to deal with a PT100. So in summary, I'm not sure you can do it. If you are an electrical engineer then you can study the schematic for the 1.5.7 and the V2 board and maybe figure something out.
Or you can buy a UM2 circuit board. Or you can get a chinese clone of the UM2 circuit board. I guess because I'm really cheap I would probably go with the last option but realize it may take a while to get it all working and it helps if you know electronics and can read schematics.
The simplest solution by far is to buy an authentic UM2 circuit board with the UM2 display. Or a UMO+ circuit board (which might be the same PCB - not sure) with the UMO+ firmware.
