Same Issue here Vasile. It's not a problem that happens at every layer. it just happends at the end of the print when finalizing the print. I don't understand the issue. It's like if the bed is moved up after the print finishes and then the print head want's to move to the side and then CRASH.
I would love to have some help from Ultimaker team on that matter !
Framar 38
It happened to me a few times. I had some print that curled up while printing/cooling (it was ABS if I remeber correctly). Every time the printer printed a new layer it had to psh against the printed parts untile the glass moved from side to side. What I did was to improve bed adhesion so the printed parts do not curled up anymore and I slightly make the metal clip holding the print glass so they grip the glass more firmly. Since then no more of this issue.
Vasile 0
I was using PLA in this case. The adhesion to the glass was very good that's why it pushed the glass away. Maybe on the picture it looks like when the part was pushed away but it was not the case. The printed part wasn't positioned in the middle. The glass is sitting also very tight in my opinion. The position of the part was too high when the nozzle moved from the "front left" side to the "back right" of the printer. The part and the nozzle collided with an overlap of about 3 mm....
