Cura stopped cutting models
Shulyapin
Posted · Cura stopped cutting models
Your answer is now as helpful as before, I have no idea what problem you have exactly.
It's the same as saying I can slice all my models with Cura without any problems, that probably won't help you either.
    No problems here 😉 but this answer will be of no help either!
    With the info provided we are unable to offer any help...
    Could be something wrong with your install... so un-install Cura, remove the Cura folder, restart your computer and re-install Cura... hopefully after that it works again!
    Posted (edited) · Cura stopped cutting models
    HERE THESE MODELS DO NOT CUT. AS THE OTHERS. REMOVED THE APPLICATION SEVERAL TIMES. CLEANED THE REGISTER. DELETED FOLDER A APPDATA. NOTHING HELPS!
    заглушка розетка.stl probka akb menshe nige.stl
    Edited by gr5
    fixed font size
    I can slice the STL in Cura 3.6. Models look fine.
    So I would suggest focusing on ehat have changed since the last time it worked (OS updates, drivers, etc.)
    No problems with these files with Cura 4.7.1... I go with @Framar: OS updates/drivers
    I would slice/print the files in this orientation...
     but in this orientation...
    ... but first you have to find out why Cura doesn't want to slice your file.
    Please share the Cura Project-File (3MF) so we have your printer and cura settings...
    File is empty...
    This is an export-file with only the model... Use the "Save Project" option... Could slice it without any problem!
    Application on my computer refuses to slice the model
    ender.3mf
    One possible cause is a blocked communication to CuraEngine. There's a firewall permission to set during installation of Cura - don't block it.
    In any case: take a look at "cura.log" and search for error messages.
    For the location of the log-file see:
    https://github.com/Ultimaker/Cura#logging-issues
    13.12.2020 в 11:07 Smithy сказал:
    firewall disabled completely
    File is OK, no problems with slicing... What OS are you using?
    Edited by Mari
    Windows 10
    Gotta be a Windows/Computer thing.  I have 4 versions of Cura and 8 other slicers loaded on this Win 10 laptop and I tried the model in about 8 of them with no problem.  Do you still have the Creality slicer loaded(?) because under the hood it's a less capable Cura and might make an alternative test.
    If you need to knock a project out maybe install Prusaslicer.  A lot of people like it.  Bit of a learning curve but at least you would be moving forward.
    You've tried "Run as Administrator" and checked all the permissions and sharing and that sort of stuff?
    I write a little code and the only way I could get my apps to run was to create Exceptions in my anti-virus.
    "Computers are not an exact science" - Me
    18 hours ago, tinkergnome said:
    Одна из возможных причин - заблокированная связь с CuraEngine. Во время установки Cura можно установить разрешение брандмауэра - не блокируйте его.
    В любом случае: загляните в "cura.log" и поищите сообщения об ошибках.
    Чтобы узнать, где находится файл журнала, см .:
    I do not understand these entries, if it is not difficult for you to check for errors. Thank you!
    cura.log
    Here is the log of my program. I do not understand this matter. Please have a look and point out any errors. Thank you!
    cura.log
    @tinkergnome - ideas?
    Well... the connection to CuraEngine does not work. We already knew that. There are no entries about a specific reason in the log file. 🤷‍♂️
    It just repeats this cycle over and over again (note the timestamps):
    2020-12-16 20:13:27,792 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.8.0\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2020-12-16 20:13:28,908 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2020-12-16 20:13:28,921 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2020-12-16 20:13:28,930 - INFO - [MainThread] UM.Backend.Backend._onSocketError [218]: Backend crashed or closed.
