Chrisp's problem seems to be a little different than Nicolinux's. If Nicolinux removes any of his teflon he could be left with an ID greater than 3mm (in some regions within the inner wall of the teflon piece), Chrisp changed his reduced inner diameter of 2.5mm to 3mm. A potentially risky proposition for a potential problem?
Edit: shoot I wrote OD where it should read ID woopsy.
196
87
78
42
Popular Days
Jan 27
48
Jan 15
41
Jan 18
33
Jan 17
26
Nicolinux 196 posts
gr5 87 posts
illuminarti 78 posts
braddock 42 posts
Popular Days
Jan 27 2014
Jan 15 2014
Jan 18 2014
Jan 17 2014
gr5 2,224
I don't quite understand but if you sharpened your filament to a point before loading would it get by the lip just fine?
I think it's reasonable to always have to sharpen the filament to a point.
Also try sliding PLA through the nylon piece that has been chewed up a bit by the extruder. Will the teeth marks of the extruder get stuck on this lip?
