So coincidentally I just learned something this week about these feeders. And I already forgot what I learned except you really really need to contact your reseller. There's some complexity with the 2 different feeder wheels and the 4 different feeder circuit boards that can cause errors if you don't do it "properly".
And if your reseller isn't familiar with this issue they need to contact Ultimaker about it. There is some bulletin or something I think that explains in great detail what works and what doesn't work and how to fix it and so on.
2
Priddy 10
If you only installed one of them, I'd go ahead and add the second one as well. They are meant to be paired together, so if only one is installed, you could potentially run into a number of issues, ranging from things like Er65s to motion controller errors.
Other common causes are things such as:
* Front fan being impacted by debris https://support.ultimaker.com/hc/en-us/articles/360011635039
* Partially clogged core https://support.ultimaker.com/hc/en-us/articles/360011620800
* Debris in the feeder https://support.ultimaker.com/hc/en-us/articles/360011652139-Clean-the-feeders-on-the-Ultimaker-S5 (I'd also recommend resetting the tension back to the middle notch)
* Waterlogged PVA https://support.ultimaker.com/hc/en-us/articles/360012057799
* Changes to Cura profile settings (Speeds, temperatures, layer heights)
If you continue to see errors after checking these, then I'd recommend opening a support ticket via: https://support.ultimaker.com/
L_Guertin 0
I installed the other matching feeder as you instructed. I checked the fan, core and feeder and they all seem fine. Our pva seems in decent condition so I doubt that's the issue. We also use the default cura profiles when printing.
Unfortunately I still get the same error.
