Hello!
I tried your answer but that wasn't the solution. I appreciate the suggestion because it made me really look at the support options and I am happy to report that I found the answer to my first question during that deep dive:
Use Towers is the setting that controls those structures.
I am still curious about the second part, getting a clean and attractive interface surface between supports and parts.
gr5 2,196
If you have a dual printer, that feature is very useful but if your supports are the same material you are printing - not so much. I'm guessing it's this one: support horizontal expansion. Set that to zero. If not then maybe post your project file here so we can look at all your settings. Do "file" "save project...". It will include your model in the project file and your printer and your profile and your overrides.
