Hi! There is a bug in Monotonic Top/Bottom function. It is visible in Preview mode while simulating print head move.
If I'm printing a cube, the diagonal filling of bottom layers is doubling at one half of bottom layer. You can try slice and run preview of project attached.
When Cura fills the bottom by zig-zag moves. It fills a half by 45 degrees moves, a triangle between three corners of bottom square. Instead of continue to fill second half toward last corner, it returns and become fill already printed bottom again. Then, after doubling bottom layer at a half of cube projection, it continues to fill the rest of layer normally, without overprinting. A huge overextrusion is observed on a half of volume. Excessive material is spreading by next layer moves and the result is terrible.
To return correct behaivour it is enough to uncheck the "Monotonic Top/Bottom" function.
Top Posters In This Topic
16
6
5
4
Popular Days
Feb 1
6
Jan 27
5
Jan 31
5
Jan 24
4
GregValiant 16 posts
ahoeben 6 posts
Nikolay_Po 5 posts
dmcneil77 4 posts
Popular Days
Feb 1 2022
Jan 27 2022
Jan 31 2022
Jan 24 2022
Popular Posts
GregValiant
Cura is not a text editor. When you load a gcode file it can display it as a preview but the gcode file itself cannot be edited from within Cura. If you intend to slice a file then you must brin
fvrmr
Hi everybody, Ultimaker Cura 4.13 is here! Last release, we focused on quality, this release we want to increase your productivity. We optimized our print profiles for Ultimaker printers. We
ahoeben
The Marketplace only contains material profiles for Ultimaker printers. Ultimaker printers use 2.85 mm materials, and since your printer uses 1.75 mm materials, the materials you download from the Mar
Posted Images
dmcneil77 0
THANKS! That fixed it! I usually don't display every setting because I only use a few of them on a regular basis. After I made every setting visible, I noticed quite a few that were activated. Spiralize Outer Contour was activated as well. I appreciate your help and getting back to me so quickly!
