If you're printing PLA, then 80°C bed temperature is probably simply too hot. Have you tried lowering the bed temperature?
/edit: Just read that your actual temperature is lower... But maybe it's still too high? Sometimes PLA sticks well even at only 40°C bed temperature...
I've noticed that sometimes, when you lower the bed temperature but increase nozzle temperature for the first layer, you will still get it to stick nicely. Sometimes you can also drop the bed temperature right after the first layer is complete. But that depends on the material of the heated bed.
This was quite tricky with my Basalt bed, but with my new PEI plate I can do pretty much anything and it still sticks like crazy
Dim3nsioneer 557
I wonder if covering the unused area with something thermally isolating might help.
I think the effect is caused by rising hot air from the bed slowing down the cooling of the deposited material.
What fan speed did you use? (And why does your temperature sensor show higher temperature? :blink: )
