DidierKlein 729
You can do some cool stuff with XT, it prints more clear when heated up (250°c with no fan) and more opaque when lower 235°c with 100% fan.
You can see the difference here:
I think that spiralize helps with transparency also.
This is a print in Ultimaker Natural PLA:
It's more opaque because of the shell thickness
But put a Led in it:
Overall regarding transparency i think that Natural PLA from Ultimaker does a good job
tmrevlje 1
Thanks for this extensive testing of the model with Colorfabb's XT material, just as you said the number 6 and 8 do seem best, I would go for number 6. Will use your settings and try it with the "Transparent Red" I received from Colorfabb.
Will also most certainly invest in a spool or two of the XT, it seems a material to be played with, capable of achieving some really cool results.
Looking forward to your results with the translucent green and blue.
