Or more specifically, what physically happens to PLA at temps above (but near) the glass temperature?
It deforms under stress. So, in your case, it will most likely deform.
I would recommend ABS, Nylon or ColorFabbTX
Thanks for the feedback.
IRobertI, it's funny that I overlook the simplest things!! I actually printed a smaller test version. I'll heat some PLA with boiling water and see what happens!
I'll be trying some out as idler pulleys in the garage. the machined pulleys I made wobbled something fierce and were making the X-axis on my router whip like crazy. Hopefully that smooths things out a good bit.
XT and ABS have a similar Tg, about 75C. I doubt those would work very well either at 100C.
XT is indeed about 75C, but ABS is definitely more -- some are going well beyond the 100C
I am not a big fan of ABS (because of the fumes), but I use it for my model cars where temperature goes above 70c and it stays hard.
This website gives tg for plastics and they list ABS between 80 and 125C, so there is a full spectrum, not all ABS are equal
Point taken. I always appreciate being corrected
I did some destructive testing on an ABS object which I had heated on the heated bed to 90C.
While it still feels solid at 90C, it permanently deforms rather than flexing when you put some load on it. So I would not use Ultimaker ABS above 80C.
I would love to have ABS that keeps it's mechanical properties above 100C but I doubt that you can buy such ABS as a printable filament (?)
Polycarbonate is what I aim for when it comes to printing objects that can resist high temperatures.
Nylon PA6 has worked fine for me in boiling water. I got it from here:
PA6 is easier to print than most of the Taulman nylons although Taulman Bridge is even easier but probably too flexible for your needs. PA6 is what I recommend. Or ABS.
Don't put PLA in boiling water - do this instead - boil some water in microwave in a mug or glass. Then remove and place on counter. The water is now already down to 80C. Take some PLA (filament or a model) and insert into the water for 10 seconds. Remove from the water and push on it. It has zero strength - it's like clay.
YOU WILL NEVER FORGET THIS EXPERIMENT. There is something about tactile learning that is better than learning by reading.
Hey gr5, I'm thinking of getting some PA6 from George.
Are there any special requirements? What temperature is it printed at? Speed? Layer thickness? Does it need something more than a heated bed to stick? What bed temperature should be used?
I have a UM1 with self built heated bed.
Sometimes we deliver prints to customers. One day, we left a customers PLA print in the car for about 20 minutes. When we got back to the car, the print had permanently warped.
From that day on, I won't go near PLA for prints that require even the slightest amount of heat tolerance. That includes heat buildup form moving pieces.
ABS has worked well for me, but like Amedee said, not all ABS is created equal. So far I find that the cheap Chinese JET brand (from amazon or 3dsupplyworld) holds up to heat pretty good. I have to print it full blown 260, no fans. Other ABS brands I've tried I can get away with 235 to 250.
I've had some trouble getting PA6 to stick with larger parts (> 100mm across) but I've gotten it good enough for what I needed so I haven't investigated further.
Nozzle temp has to be very hot - I print at 260 nozzle. Always. Any cooler and you get bad layer adhesion. For the same reason I print with fan at 30 to 50% (both seem fine).
Now the tricky part - getting it to stick. Of course you need brim.
I've gotten it to work with PVA glue and bed temp of 80C. That was my best result so far. Next time I will almost certainly try 100C.
Alternatively I've gotten it to work on blue tape at 50C. My notes say don't go hotter than 50C because then the blue tape doesn't stick very well. I recommend you try PVA on glass rather than blue painters tape. 80C on glass seemed much better than 50C but I'm not 100% certain.
I haven't tried kapton tape.
fbrc8 is Simon aka Illuminarti. Not me. He's also "Ultimaker USA" now.
George, sorry about the name mix up. Right Simon = Illuminarti = fbrc8.com
Thanks for the printing info. I'll give it a try
Unfortunately, the part will be about 125mm across so we will see how the adhesion goes.
Have you tried hairspray on glass? That worked well for XT
My self built bed is 240W so should be able to get to 100C without probems.
I'll let you know how it works out.
I have tried hairspray on glass for ABS but have not tried it for Nylon. 95% of my prints this year have been PLA.
This suggests PVA glue on glass. I used wood glue but this guy used glue stick. Also different types of nylons are easier/harder to get to stick to glass:
http://forums.reprap.org/read.php?1,233826
This guy likes glue which I strongly suspect is PVA also:
http://www.thingiverse.com/thing:114868
Or make a print and use it to cast epoxy.
IRobertI 520
I doubt PLA would work, it will become much too soft to stand up to the constant grinding. Drop one of your failed prints into boiling water, take it out after a few minutes and see how it behaves.
But I have no practical experience so don't take my word as gospel (numbers don't lie though).
