Cura 15.06.02
TheDeugd
Posted (edited) · Cura 15.06.02
just downloaded it, and installed it, First run (with the printer on) it turned off and immediately again on... it was like blinking... and the came this error message (YOSEMITE 10.10.3)
[media=3754][/media]
    • Replies 54
    • Created
    • Last Reply
    Posted Images
    Posted · Cura 15.06.02
    The profiles for BQ printers have been adapted for the new version of Cura (15.06). I am sure they will be available in the next Cura release.
    They will be.
    I want to print a small model. In trying to determine the optimum printing speed I played around with printing speeds.
    At a printing speed of 20 mm/sec the reported printing time is 40 minutes
    At a printing speed of 25 mm/sec the reported printing time is 36 minutes
    At a printing speed of 30 mm/sec the reported printing time is 35 minutes
    At a printing speed of 35 mm/sec the reported printing time is also 35 minutes
    At a printing speed of 50 mm/sec the reported printing time is 2 hours 22 minutes.
    Obviously something is very wrong here.
    Unfortunately the uploaded images in which you can see the reported printing times cannot be seen in full scale in the forum.
    Also, even though I have checked "Follow and receive reply notifications" in every topic I have followed, I never receive any notifications.
    5a330fac76dbc_ScreenShot2015-07-22at3_57_43PM.thumb.png.6592be7464198985234cf214ee96754e.png
    5a330faca0a21_ScreenShot2015-07-22at3_58_02PM.thumb.png.f5e3d4fa6049b80b4d802493ef3fc32d.png
    Have you double checked that topics that you follow end up in my profile > following? And have you checked the bell icon in the menu bar for notifications? These notifications seem to work fine on my end, I got a notification from you actually because I'm following this topic.
    If you're talking about email notifications, that's something that isn't there yet. We're working on that right now to launch soon.
    I had a similar issue tonight. I loaded and tweaked a model that should take 5.5 hours to print. It became 20 hours for some reason. I removed the Ultimaker2 printer that was listed in Cura (This machine profile was brought over from 15.06.01, I think), then I added it again, and the print times were more reasonable.
    In the Layers view I can't see the blue lines showing print lines or retractions. Is there a way to enable those? Those lines were present in previous versions of Cura before the 15.06, and they're very helpful for me when using a pause command. Blue lines let me see whether or not after resuming the first thing to get printed will be the scratch block over in the corner.
    Nope, no way to enable that. It should be added eventually, don't know the timeline on that.
    Thanks.
    Something I can't figure out how to control the speed of in 15.06.02 is the movement speed during combing.  I have the travel speed set to 200 mm/s in Cura, and in the UM2 hardware settings I have Max X = 200, Max Y = 200.   It seems like all movement is 200 or less except during the combing actions, which happen at breakneck speeds.  How can I slow that down?
    edited to add: This issue of mine may not be related to 15.06.02. I think I just don't understand all the movement and acceleration functions yet. Turns out I was over extruding in my current print because of a wrong diameter filament setting. Globs were building in a couple places, then the nozzle would run into one at high speed and cause the nozzle to be off for the rest of the print. Maybe it's all going same speed now as it was yesterday when I was using 14.09
    Encountered the following issue with Cura 15.06.01 and 15.06.02:
    The build plate background isn't loading, and the tools for rotate/scale etc aren't appearing when the object is selected.
    Two computers were tried, both running Win7.
    Any tips? 15.04 works fine on both of the computers Cura 15.06.01 and .02 isn't working on.
    Just want to report a finding: layer view after rescaling object showing previous object size.
    I opened an STL. Both the solid and layer view work fine.
    Rescaled the model:
    - Solid view is showing the rescaled object correctly.
    - Layer view is showing the object in its original size.
    Rescaled the model again:
    - Solid view is correct.
    - Layer view is showing the previous object size after the first time rescaling.
    OSX 10.10.4
    Cura 15.06.02
    Hello Forum, im unable to run Cura on teh alst eversion of yosemite. Someone Out there who can Run Cura on Mac?
    Please report issues on the github. Its almost impossible for us to keep track of issues on the forum.
    By that logic, perhaps we should use github for all our discussions... Badumtisch!
    (I'll show myself out...)
    Lol, discussion is fine. Thats wat it's for.
    I must say I like the clean look of having no checkerboard. I may have to tinker with the shader for the buildplate...
    Hi, I have installed it on Windows 7 OK but when I installed it on Windows 10 it crashes and the system is unable to fix it. Any ideas how to proceed?
    I kinda do too! Now if only the tools for the settings would show up, I'd have nothing to complain about. :)
    Cura 15.06.02 gives the time and length of filament use but did the new release drop the number of grams used for a job? Spools are sold by weight and pricing costs of jobs for clients was very helpful. Now it appears gone. Is it located somewhere or can I customize it to display the jobs in length of time and total weight used in grams?
    Thanks.
    John
    It looks like this functionality will return in the form of a plugin in one of the next releases of Cura. I think you can manually add the plugin in your current version:
    https://github.com/nallath/PrintCostCalculator
    Thank you, ahoeben. I will give the plugin a try.
    zews
    Level 3 - Hobbyist
    Posted Jul 26, 2015 - 3:15 PM
    Edit post
    I have posted the following before, unfortunately nobody from Ultimaker has responded about this. Also unfortunately the same thing is happening again now.
    For a model I currently want to print Cura reports the following:
    At a print speed of 50 mm/sec the reported print time is 2 hours and 47 minutes
    At a print speed of 40 mm/sec the reported print time is 3 hours and 18 minutes
    At a print speed of 30 mm/sec the reported print time is 4 hours and 12 minutes
    At a print speed of 25 mm/sec the reported print time is 4 hours and 57 minutes
    At a print speed of 20 mm/sec the reported print time is 2 days, 9 hours and 54 minutes!
    I really wish somebody from Ultimaker would respond to this, and tell me either what I can do to fix this or tell us that this is a known bug and when a fix for this will be available.
    5a330fb4e5976_ScreenShot2015-07-26at3_04_47PM.thumb.png.f83c498269a0f49ee85c22460e454dd7.png
    5a330fb5202a8_ScreenShot2015-07-26at3_05_13PM.thumb.png.f11b2a29c7962326e9b0f0afc05075a3.png
    How can one see an added image in full size once it is uploaded? This was easily done in the previous version of this forum, and now I can't seem to figure out how to see a full size image.
    I can run Cura 15.06.02 on my Mac running OS X 10.10.2
    However, I find that a lot of things do not work properly and I am constantly reverting back to 15.02.1 for printing.
        • 2 replies
