Hi Meduza,
Really liked your way of doing it.. It's a "Roll Royce" feeder unit, imo.
I made a very simple belt gear with a 16 and 32 theeth 2GT Pulleys. I used same belt as the two short ones in the UM2. Two small (outer dia. 10mm and inner 5mm) bearing a 5mm shaft from a model helicopter and two adapted 6mm plexiglass sheet. Sure there is 5 ea 18mm spacers in there too.
I have been printing for about 11 hour in this way, an it does not make much noise -only the stepper backtracking is noticed, but this is like the other steppers. I've made this with normal hand tools, not very nice but work very good.
Do you share your stl files for other? I would love to make your pro. ver..
Thanks for sharing your idea.
Regards
Torgeir.
neotko 1,417
Well the problem wasn't the feeder but the ptfe coupler was dead. So it works
I need to run some mm3 test.
puremoco 15
Since I have some issues with the "clicking" of the feeder and many aborted print, I have decided to upgrade the feeder.
A reduction with a pulley seems to me more suitable than with gears.
I have disovered meduzas feeder, but I am missing an easy solution to adjust the belt tension. Furthermore, it would be somehow difficult to order the exact belts and pullys here in Germany.
This is my first test, so maybe there will be a second version later.
The stepper will be replaced by a Trinamic NEMA17 (200 steps), which is optimized for microstepping.
I must have a look where to place the whole feeder, since I am using 2.2kg spools (30cm diameter)
Edited by GuestLink to post
neotko 1,417
I finished installing two gear boxes on um2 motor and umo motor. And it's quite weird. UM2 motor keeps giving me bad prints with errors on the retracts/print (40k retracts per print). I removed any other posible think by just placing the um2 + gear on the perfectly working umo gearless. And the errors pop. It's like if the um2 motor fails on a small but noticeable amount of movements.
I started to check about 1.8 vs 0.9 motors and found this info, maybe someone with more knowhow can check this.
As far as I see it by my prints, if I put the um2 motor on a already working machine, my prints get errors (with and without gears). I wonder if lowering the step for the feeder to 1/8 might help to have a more accurate magnetic movement from the motors. I don't get errors (that I can see) when the print it's 10k retracts, but at a full plate 40k for 6 keychains I see mistakes on infills and small letters (compared to two other umo+ with same gcode).
Well so far I would not recommend gears on 0.9 motor unless you lower the stepping to 1/8 + gear. But I been wrong in the past and I need more tests.
https://groups.google.com/forum/m/#!topic/deltabot/uuhSyAI81Hg
"Tim, that's accurate, microstepping only adds precision up to around 1/8 or 1/10 stepping. Beyond that, the angular size of each microstep is likely to be smaller than the natural error tolerance of the motor. Magnetic decent and fab precision issues (eg worn stator stamping dies) cause much larger position errors than a single 1/32 step.
Full steps and half steps are likely to be more accurate in absolute terms than microsteps, because they represent symmetrical magnetic field positions. The magnetic detent effects aren't trying to bias the rotor in a particular direction. Quarter steps may have poor accuracy, that's when the permanent magnet is most trying to shift the rotor and the coil fluxes are quite unbalanced to boot. It depends on how the manufacturer optimized the geometry. Maximum holding torque designs may mean smaller than desired microsteps near full steps. It's a complicated science."
puremoco 15
@neotko:
For my camera rig, I also use steppers. I also have encountered, that microstepping is not suitable for precise movements. I posted a topic in the pololu-forum:
http://tinyurl.com/gm5eju3
At the bottom, you can see some tests, which I have performed at full stepping and 1/8. As you can see 1/8 is very irregular with a standard stepper.
You can also see, that the Trinamic stepper is performing much better at 1/8 than a cheap "chinese" stepper.
http://www.trinamic.com/products/motors/motors-stepper/qmot-qsh4218
The stepper drivers are also responsible for accurate microstepping. The A4988 in the UM2 are very old technology and there are much more sophisticated drivers, like the TMC2100 (aka SilentStepStick), on the market for the same price:
http://www.trinamic.com/products/integrated-circuits/stepper-power-driver/tmc2100
Unfortunately, the SilentStepStick-drivers can be only replaced with the UMO. The UM2 has the A4988 drivers directly on its PCB... Maybe there will be replacement in the next UM-generation.
neotko 1,417
Thanks @puremoco my digging on this it's a very see-print-see-repeat-check-repeat approach I don't have much knowhow that all I have read and learned this year. But there's something weird on the behavior. Specially when the retracts happen 30k in just 1h
