Dim3nsioneer 557
As @swordriff is on holiday, I try to answer those questions. Maybe @gr5 and @DidierKlein can add or correct (one of you guys had that comparison picture recently iirc).
The 0.15mm and 0.25mm look like your first picture. All other sizes look like the second picture. However, at least the 0.25mm nozzle has changed its look very recently. On the inside and around the tip they are they same; including the important angles.
The 3dSolex nozzles and the Olsson block respectively have a M6 thread, so it's compatible with e.g. E3D nozzles. Just make sure you have a nozzle for 3 (2.85) mm filament diameter and not 1.75mm.
3dnerd 6
I don't want to push - but may someone can help please?
Thanks...
