In cura 2.1 this is done by changing the "print sequence" setting
One at a Time printing is not supported for multiextrusion printers.
7 hours ago, ahoeben said:One at a Time printing is not supported for multiextrusion printers.
It will be in the next release; in that release you can disable unused extruders. So as long as you don't use both extruders, you can print one at a time.
1
- 2 years later...
I was looking at this post and I am using Cura 15.04.6 and under tools it does have the print on at a time option but when I select it and then load it on my JGAroura A5S it doesn't do anything It still printed all at once. Is there other setting that need to be changed also?
Thanks Binderchk
15.04.6!!! Nice! That's a good version! From 2015. I remember it well. Well go into machine settings and set gantry height to something taller than your prints and set the 4 distances (something like left/right/top/bottom) - the 4 distances from the nozzle to the edge of your head - to the actual values and make sure your parts are farther apart then those distances indicate (cura will extend the shadow of the part based on those 4 numbers).
Then it will indeed do "one at a time". You can use the scroller to see that it prints all of one part before starting the second part. No need to actually turn on the printer to know if it worked.
Wait are you really using cura 15 with an S5? You will need to use a newer version of cura if you are printing on an S5 but the instructions are basically the same except your parts need to be *shorter* than the gantry height in device settings.
skinny-kid 65
In Cura under Tools check "Print one at a time" instead of "Print all at once"
This is influenceed by the height of your print. If objects are too tall then this option may not be available.
edit - assuming you are using Cura that is.....
Edited by GuestLink to post
IRobertI 521
In addition to what skinny-kid said, I've found that sometimes you need to nudge one or two of the copies to make it re-slice properly when you change that option.
Jasu 1
Thanks for the pointer, Skinny. Should have spotted that myself. I'm posting a screenshot for those other newbies who don't find that right away.![5a3319e37aaa8_allatoncevsoneatatime.thumb.png.f2a294f4aa17298e311e662f4faf3a2b.png](//content.invisioncic.com/ultimake/monthly_2017_12/5a3319e37aaa8_allatoncevsoneatatime.thumb.png.f2a294f4aa17298e311e662f4faf3a2b.png)
