I've been looking already but can't find a good source for the 4x4mm rods, any supplier tip?
I can help you, I bought it on ebay
1
Thanks!
Op 'spiestaal' zoeken, je vind zeker iets in je buurt voor 2 keer niets...
Hi to all !
Mark2-Dual ZGE more and more tests.....
Cura 15.04.6 vs 2.7 version, with same basic print settings
old Cura 1h28
2.7version 1h49
here the result before post cleaning of the print test done it seems a bit better on the right with Cura 2.7 vs the left sliced with the old 15.04.5 version, better temperature control !
It 's really a shame that Cura did not think to allow the Ironing application to specific layers during the print and not only on the last top layer which in many cases is not necessarily flat, as the sample here, or as thousand of others print models designs !?
BTW thanks to Lara Steele the author of the dragon design dowloaded from Thingiverse, I just customized the round base.
Hey Gudo, very nice build!
I also like the way you solved the object cooling fans, I have to copy that
Anyone has ever tried UM Marlin on a corexy setup? ...
I did a year ago. Transformed UM2 having corexy inside the frame, while using standard UM2 firmware. I did have some problems with "define Quick_Home". You should not use this option in combination with corexy.
I'm also thinkering on dockable um3 cores. Downside of using ultimainboard, is having only 2 heaters available (+build plate ofc). While using corexy, there should be many more cores inside...
ultiarjan 1,209
Great! no hurry,
I was planning on getting a bom together based on the "normal" zge and the m2 version, but if you provide it it will be much more reliable I'm sure.
