Quote by driedeedesignOn Mac you select the application, right click -> show content -> Resources -> resources -> shaders -> select the file grid.shader right click and edit with Text editor ... copy n paste (replace) the text ...
And you don't get a "Cura.app is damaged and cannot be opened" dialog after making that change?
Here the same, (macbook pro 2110). Worked great. There is no 'resources' in the Application Support-cura.
ahoeben 1,955
